no budget home wifi solution
kaspermv
i am working on a wifi setup for my uncle and they just built their new 2 story house with cat7 cables run everywhere but he really only uses wireless. the house is build near the beach so they needed to make a full concrete seperation therefore the wifi cuts completely when moveing to the upper floor.
they are not "power users" but they want speed and amazing coverage. the budget is undefined but they need a soloution that reguires zero babysitting as well as seamless transfer between accespoints.
what do you guys think is a viable solution. my first thougt was a ubiquiti setup but i dont really have any basis for that choice other than linuses use.
ps. products available in denmark is very much preffered.
Just buy a nice router.
Download a free wifi scanning app on your mobile and find any dead spots (if any) - I have a 5600sqft house (huge) and a single, centrally placed router that gives 90% at the very edge of the house from my 2gb internet connection.
If there are any.. since the house is wired.. just place a access point in that location.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
If you want a really cheap solution you could pick up 2 of these Xiaomi routers. They are available for around 7€ on eBay.
But I would advice the same as ttam, a good router in a central location should do the job. My dad has a AVM FRITZ!Box 7590 (don't know if they are sold in denmark, also costs 200€) and it covers his 3 story house plus garden pretty good.
Main Rig
CPU - i7 6700 | RAM - 16GB (2x8GB) G.Skill, 16GB (2x8GB) Crucial OEM | GPU - MSI GTX 980 Gaming | PSU - Cooler Master G450M | Storage - 1x 256GB Samsung SM951 (NVMe)(System), 2x 500GB Samsung 860 EVO (Striped) | Case - Fractal Design Define R5 (with TG side Panel) | OS - Windows 10 Pro
NAS / Docker Host
CPU - Xeon E3-1220v3 | RAM - 16GB (2x8GB) Kingston ECC | PSU - Enermax Revolution SFX 550W | Storage - 3x 4TB WD Red, 1x 2TB WD Red, 4x 3TB Seagate Constellation, 2x 250GB Samsung 850 EVO (Cache) | Case - AVID Unity Media Engine (3U Rackmount) | OS - UnRAID OS Pro
VM Host
CPU - Xeon E3-1246v3 | RAM - 32GB (4x8GB) Samsung ECC | PSU - Enermax Revolution SFX 550W | Storage - 2x 512GB Samsung 860 Pro (System / "Fast" VM's), 4x 500GB HGST (RAID 10) | Case - Avid Unity MediArray XT (3U Rackmount) | OS - Windows Server 2019 Datacenter
Notebooks
Fujitsu Lifebook E756CPU - i5 6200U | RAM - 8GB DDR4 OEM | GPU - Intel HD 520  | Storage - 250GB Crucial MX500 | OS - Windows 10 Pro
Apple MacBook Pro Mid 2015 | CPU - i7 4770HQ | RAM - 16GB | GPU - Intel Iris Pro | Storage - 512GB Toshiba XG4 NVMe | OS - macOS 10.15.1
first of all think my title was unclear. as in they have no fixed budget
with that out of the way... i tried a asus RT-AC88U and that was unable to cover the corners with fast enough wifi.
my problem with just adding a AP is the lack of seamless handoff. theyre kindda looking for an enterprise or school type of network if that makes sence.
thank you so much for the hastely replies
So I'd go for something from Ubiquiti networks. They have great APs, I have two of them Running here and the handoff is seamless. Only downside is that you need a controller as they can't run standalone. You can solve this as a VM or you can buy the Ubiquiti Cloud Stick (which is basically only an ARM linux box running the controller software). You should also be able to use a Raspberry pi or a similar board as a controller as there should be an ARM-Version of the controller software.
  • one AP of the ac-series is around 90-150€ (depending on which model you get)
  • cloud key = 80€
single board arm computer (e.g. Raspberry pi) = 10-35€
EDIT:
you still need a router/modem combo so that you have a DCHP/DNS-Server on your Network. The modem provided by your ISP should be reasonable for this.
Main Rig
NAS / Docker Host
VM Host
Notebooks
so lets say i went for two Ubiquiti Unifi AP-AC Pros and the cloud stick. would i be up and running without any other hardware?
i seem to recall linus useing a sort of router box in his pimp my wifi episode. is that nessesary or can i use a standard isp router for the dhcp assignment
Yes, you still need a router for dchp assigment. The box of your ISP should do the job ;)
Even if you would buy a Ubiquiti EdgeRouter you would still need a modem to translate your DSL/Cable signal.
I'd go for the ISP-Box it's free and can do everything you need.
Main Rig
NAS / Docker Host
VM Host
Notebooks
also note that you need to assign the controller a static ip. Either you assign it in the dchp server of the modem or you set a static ip on the cloud stick (or both)
Main Rig
NAS / Docker Host
VM Host
Notebooks
