So i tried a couple of online jailbreaks which oviously didnt help but while doing it showed preparing xatab files pushing jailbreak to your device bla bla. So after it failed. I want to have my clean device back. I want to revert any chances those jailbreak sites would have done. Is a full reset enough or i should flash firmware?
https://linustechtips.com/topic/882803-ios-1121-help/
You should be able to put you device into DFU mode and restore / reset with itunes. How to here
[DESKTOP] CPU: Intel Core i7 8700k GPU: ASUS ROG 2080TI RAM: 64GB Corsair Fury DDR4 Mobo: Asus z390-A Prime
Storage:1x 1TB Samsung 990 Pro SSD 2x 1TB WD Black SSD, 2x 3Tb Seagate  HDD PSU: Seasonic 950W
Monitors: 2x Asus TUF Gaming 24" 1440p  144hz, 2x LG  75Hz 1080p LED
[SERVER/NAS] CPU: Intel Core i7 7700K GPU: Nvidia 1060 6GB RAM: 32 GB Corsair Vengeance Mobo: Asus z-170P D3
Storage:1x 1TB Western Digital SSD, 4x Ironwolf Pro 12Tb HDD, 2x 2TB WD Blue  PSU: Thermaltake 650W
[LAPTOP (MacBook Pro 16")] CPU: 2.4 GHz 8-Core Intel Core i9, RAM: 32 GB 2667 MHz DDR4, SSD: 2 TB
GPU: AMD Radeon Pro 5500M 8GB Display: 16-inch (3072 x 1920)
https://linustechtips.com/topic/882803-ios-1121-help/#findComment-10909609
