Dad wants a new rig,
What it needs to do:
- Stream live sports
- Browse buy and sell websites
- Watch youtube
- Watch movies
-occasional design work, (cinema4d, maya + adobe suit)
Budget for the cpu + mobo roughly around the 300 mark, and also advice on a power supply unit.
I can get my hands on cheap ram and a cheap 250 ssd and I'll probably buy some cheap case online,
Ideally an intel (as i already have a couple amd computers already), and also something a bit future proof .
Thanks
https://linustechtips.com/topic/882744-advice-on-cpu-mobo-combo/
- Watch youtube
- Watch movies
Thanks
Making one rn.
CPU: Intel Core i9 9900K | Ram: 32GB Corsair LPX 3200 DDR4 | Asus Maximus XI Hero Z390 | GPU: EVGA RTX2080 XC | 960 EVO Samsung 500GB M.2 | 850 EVO Samsung 250GB M.2 | Samsung 1TB QVO SSD | 1TB HDD WD Blue
If that's all he does, get a g4560 + h110 board. Should cost around 100 usd bundled.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
EDIT: forget this, misread post
- Watch youtube
- Watch movies
Thanks
https://pcpartpicker.com/list/xBwMPs Heres for paps. Expandability Able to store everything and is fast.
should have put this in the post, but would like at least want a 4 core, in case i ever need to do design work on it, thats why i put a $300 budget
300 budget is for cpu and mobo only, dw about the rest.
lmao well theres a 300$ Pc
are the i5 kaby lake processors any good?
Way too overkill for him.
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($200.98 @ Newegg)
Motherboard: Gigabyte - Z370 AORUS GAMING WIFI (rev. 1.0) ATX LGA1151 Motherboard  ($100.98 @ Newegg)
Total: $301.96
Generated by PCPartPicker 2018-01-06 23:45 EST-0500
https://pcpartpicker.com/product/dDH48d/corsair-txm-gold-550w-80-gold-certified-semi-modular-atx-power-supply-cp-9020133-na for the PSU
Total: $301.96
this looks good, many watt psu you reckon? wont be running a dedicated gpu anytime soon
a good 400-550w unit is more than enough. i'd suggest getting a low-end nvidia gpu for CUDA acceleration.
