Hello, i recently been looking into starting to stream but my pc is not too strong for that and wont handle the load of streaming and playing at the same time i need some recommendation on what CPU i should buy because i dont really know what is compatable or is not to my motherboard.
PC PARTS
GPU - AMD Radeon R9 390
CPU - Intel i5-4590 - 3.3ghz
8gb of ram
motherboard - ASUS Z97 ATX
650W power block
https://linustechtips.com/topic/882682-newb-needs-help-with-upgrading-a-pc-help/
Well you should look firstly on gpu's but maybe the problem is network? I stream on steam (little not optimized) so my friend watches some gameplay and it runs smoothly (60fps, no lag on stream nor game) with my 1.0-3.5MB/ps down 1.5-5.0MB/ps up. And your system is better than mine actually.
My rig
G3258 not overclockable
4GB ram
500GB hdd
430w Apevia psu (Not 80 plus)
HD 7850 oc'ed
Win 7
Just now, idensity said:
my internet is good but its like laggy - download 126mbps upload 128 mbps
Hmm. Maybe you have many background apps? That may be a problem. Also don't download and stream at the same time, it will give u lag.
have you tried to stream on twitch smoothly? i tried to stream csgo on optimized settings and i just couldnt ingame lagging stream lagging and my pc's fans were going off i think the cpu cant handle the tasks and i always turn off everything when i stream
I could stream CS:GO on my i5-750. Granted, it was at 720P and 30FPS, but it was smooth and of decent quality. Your system should handle it just fine, as long as your network is fast enough.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
No I haven't streamed on twitch. Now that seems just like bad luck. Maybe it is software related buddy :P.
