Ok so on my laptop every time I turn it on the windows 10 touch screen keyboard keeps popping up (not the on screen keyboard because I turned it off) it’s so annoying and the laptop is not even touchscreen it’s a Hp Compaq Presarion cq57 (old laptop yes I know ) how do I turn off the windows 10 touch screen keyboard!?!
https://linustechtips.com/topic/882214-so-annoying-need-help/
You can turn off the on-screen keyboard in your settings.
Settings > Ease of Access > Keyboard
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/882214-so-annoying-need-help/#findComment-10902552
I said it’s not the on-screen keyboard I did that a long time ago it’s off. I’m talking about the windows 10 touch screen keyboard not on screen keyboard
https://linustechtips.com/topic/882214-so-annoying-need-help/#findComment-10902579
On-screen and touch keyboard are the same application and function identically. Turning it off within ease of access should disable the touch keyboard. If it does not, you'll need to go into the registry.
Quote
Enable or Disable OSK Via Registry
  1. Hold down the Windows Key and press “R” to bring up the “Run” dialog.
  2. Type “regedit“, then press “Enter“.
  3. Navigate to the following location:
    • HKLM
    • SOFTWARE
    • Microsoft
    • Windows
    • CurrentVersion
    • Authentication
    • LogonUI
  4. Open “ShowTabletKeyboard” and set it to “1” to enable it. Set it to “0” to disable it. If this key doesn’t exist, you can create it.
https://www.technipages.com/enable-disable-on-screen-keyboard
Desktop
Homelab
https://linustechtips.com/topic/882214-so-annoying-need-help/#findComment-10902598
Omg thank you so much
https://linustechtips.com/topic/882214-so-annoying-need-help/#findComment-10902650
