I got a dark rock 3 from be quiet for Christmas, and when I installed it my system didn't post. I tried to configure my memory in different setups, to see if that helped. I have 2*8 sticks and i seated them in the second and fourth sloth. When I pulled out the memory in the fourth sloth, it finally posted. Sometimes it posted but I didn't get any signal to my monitor, and other times it tried to post but it just turned off again. But I wanted the second stick in there as well so I tried and I tried, and when I hit my cpu cooler (bumped into it), it worked again with two sticks. But then I installed a new fan and touched the cpu cooler and know I am having the same problem, only the second slot work. Any thoughts?
My specs are:
4770K not overclocked
MSI Z87-G45 GAMING
Crucial DDR3 16gb (2*8)
MSI GTX 1060 6gb Gaming X
Corsair CS 750M
https://linustechtips.com/topic/882060-memory-or-cpu-problem/
