I'm going to be getting a new PC in january, but i dont have enough money for a graphics card, so im going to be using my GTX 460 in it until i have enough money. I was worried tho as it comes from a dell pre-build PC would it work in a different PC? The motherboard is a Asus Maximus VI formula.
CPU: i5 4670k / Cooler: Corsiar H100i / RAM: 2x4gb Corsair Vengeance Pro 1600mhz / Motherboard: MSI Z87-G45 GAMING / GPU: Asus r9 290 DirectCUii / Case: Define r4 / Storage: 128gb Samsung 840 EVO & 2tb Seagate barricuda / PSU: Corsair RM750
https://linustechtips.com/topic/88115-gtx-460-help/
it will be fine as long as the psu has enough power. do you by chance know the psu that pc will use?
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/88115-gtx-460-help/#findComment-1193767
Corsiar RM750 or RM850
https://linustechtips.com/topic/88115-gtx-460-help/#findComment-1193774
I see no reason for it not to work:)
Case: Corsair 460X RGB bby, CPU: I5 8600K, Motherboard: MSI B360M PRO-VDH, RAM: 8GB Hyper X 2400MHz , Graphics Card: GTX1060 6GB, PSU: Corsair RM750x,
Cooler: BEQuiet!  Pure Rock Slim SSD: Kingston 240GB, HDD: 2TB Seagate Barracuda
https://linustechtips.com/topic/88115-gtx-460-help/#findComment-1193798
Yeah, fine. You'll survive off that for a while. Trust me, I survived on a GT 610 before getting my 570!
LOOK AT MY TUBE, MY TUBE IS AMAZING. DONT LICK IT IT DOESN'T TASTE LIKE ANYTHING. IT DOESN'T HAVE A MANE OR PENIS EITHER. SHUT UP.
https://linustechtips.com/topic/88115-gtx-460-help/#findComment-1193800
okay thanks :)
https://linustechtips.com/topic/88115-gtx-460-help/#findComment-1193809
800w is apparently the recommended minimum requirement for two 780's in SLI. You'll be fine.
•  i7 4770k @ 4.5ghz • Noctua NHL12 •  Asrock Z87 Extreme 4 •  ASUS GTX 780 DCII 1156/6300 •
•  Kingston HyperX 16GB  •  Samsung 840 SSD 120GB [boot] + 2x Seagate Barracuda 2TB 7200RPM •
•  Fractal Design Define R4  •  Corsair AX860 80+ Platinum •  Logitech Wireless Y-RK49  •  Logitech X-530  •
https://linustechtips.com/topic/88115-gtx-460-help/#findComment-1194307
