Hey guys i want to know if these temps are safe or not
game Ghost Recon Wildlands
custom/high preset
CPU (ryzen 3 1200 stock cooler):- temp ~40-45
MOBO (asus prime b350m-k):-temp ~ 39-41
GPU (asus gtx 1050ti phoenix (single fan)):- temp ~67-71
8gb ddr4 2400mhz kingston memory
cx 450w psu
all these temp and i just started playing (around 5 min into gameplay).
i want to know if the temps are within the range or not because i was planning to overclock both my gpu and cpu.
and even if i dont overclock how long can i game? are the temp going to increase a lot because i got these temps just by playing for 5 min.
https://linustechtips.com/topic/881004-gpu-and-cpu-temps/
Seems fine to me. The GPU temps lead me to believe it won't have massive headroom for overclocking, though. You should be able to get the CPU up a few hundred MHz.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/881004-gpu-and-cpu-temps/#findComment-10890785
