So! I need help if what he's saying is true or not
the laptop is an old Lenovo here are the specs
Model                :    Lenovo G4070 59439341
Processor                :    Intel Core i3-4005U Processor (3M Cache, 1.70 GHz)
Operating System        :    Windows 8.1
Graphics                :    Intel HD Graphics 4400
Memory                :    2GB
Webcam                :    720p / 0.3M
Storage                :    500GB
Optical Drive            :    DVD Recordable
Audio                :    Dolby® Advanced Audio™ v2
Battery                :    4Cell
Display                :    14-inch HD (1366 x 768) Display
Dimensions (W x D x H)    :    15.11" x 10.4" x 0.98"
Weight                :    4.6 lbs.
Bluetooth                :    Bluetooth® 4.0, 802.11 b/g/n
Connectors            :    1 x USB 3.0
                        2 x USB 2.0
                        Audio Combo Jack (headphone and mic)
                        HDMI-out
                        2-in-1 (SD / MMC) card reader
So what is troubling me is that I'm going to buy this second hand because I don't have money for a new one and it's going to cost me 120$ in my country, the issue is the laptop can turn on only if the charge is connected it isn't a battery issue / charger issue he said it is a driver issue when he updated his OS it won't charge anymore so thoughts? prayers? suggestions? I really need a laptop to code in school so Yeah.
https://linustechtips.com/topic/880991-laptop-help/
1 hour ago, komar said:
@Pengich It's probably just a dead battery, witch are not that expensive to replace. That being said why bothered with a laptop like this - there are a lot of android compilers or web ones - if you have decent phone just get a Bluetooth keyboard and you are set.
Well we're not really allowed to use phones :( so that isn't an option he said got the battery replaced and charger replaced so I don't know what the problem is
https://linustechtips.com/topic/880991-laptop-help/#findComment-10890956
Definitely sounds like a dead battery. At least you know the charger is fine if it's powering on while it's plugged in. Also, people lie about stuff so unless you know it's a new battery, assume they are lying.
https://linustechtips.com/topic/880991-laptop-help/#findComment-10891851
