So I got a iPhone 8 new when it came out and it’s been a problem since day 1, my phone screen will not shut off or auto time out on it’s own. The only way is to press the sleep button to shut the screen off.
in the settings auto time out is ON and I have tried it on the lowest time setting to the highest and it just never turns off.
I forget got to shut the screen off a lot and it just drains my battery when that Happens.
restarts don’t fix it. Even a hard restart or force restart whatever you call it
ios version HAS been updated regularly.
https://linustechtips.com/topic/880876-iphone-8-issue/
Did you ever factory reset the phone? Is there some app that doesn't allow it to go to sleep? Does the issue occur when the phone is completely restored and then turned on without having downloaded ANY apps or having changed ANY settings?
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/880876-iphone-8-issue/#findComment-10889563
Enter DFU mode and hookup to your Mac or PC and select restore in iTunes.
This will wipe the iPhone's internal SSD and reinstall iOS from the internet.
You may backup if you like but your backup might contain the error and if you restore the error you will be back at square one.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/880876-iphone-8-issue/#findComment-10889566
So it has to be a glitch or error in the software?
https://linustechtips.com/topic/880876-iphone-8-issue/#findComment-10889573
Nothing hardware related should prevent the phone form turning the screen off automatically.
https://linustechtips.com/topic/880876-iphone-8-issue/#findComment-10889579
It's either a glitch, a setting in the settings app, or a setting you missed in some other app that forces it to stay on. It's stupidly unlikely that it's a hardware issue.
PSU Tier List | CoC
https://linustechtips.com/topic/880876-iphone-8-issue/#findComment-10889580
Like what broke? The freaking clock?
https://linustechtips.com/topic/880876-iphone-8-issue/#findComment-10889583
It's either a glitch, a setting in the settings app, or a setting you missed in some app that forces it to stay on. It's stupidly unlikely that it's a hardware issue.
I don’t feel like restoring my phone at least not right now, I’ll look alrind more but I’m guessing that’s what I need to do to fix it
https://linustechtips.com/topic/880876-iphone-8-issue/#findComment-10889584
If auto lock does not work there is nothing else you can do outside of a reset or restore.
Depending if you have anything to backup the whole process should only take less than 15min or so.
https://linustechtips.com/topic/880876-iphone-8-issue/#findComment-10889590
Some apps can block auto lock. Logitech's Harmony App will prevent it from locking if the app is open -- not knowing what he has running on the phone makes it impossible to say for sure that there isn't some app or setting that needs to be changed somewhere.
PSU Tier List | CoC
https://linustechtips.com/topic/880876-iphone-8-issue/#findComment-10889593
There is only one setting that affects auto lock and thats "auto lock" lol.
https://linustechtips.com/topic/880876-iphone-8-issue/#findComment-10889597
Unless there is some app that is overriding it.
PSU Tier List | CoC
https://linustechtips.com/topic/880876-iphone-8-issue/#findComment-10889600
Unless the app developer figured out how to break the sandbox that only works if the app is open and in the foreground.
https://linustechtips.com/topic/880876-iphone-8-issue/#findComment-10889602
1 minute ago, thefatcat2017 said:
I would get with Apple and see if they will fix it for you or replace it. I would find that to be more worth it than doing it yourself because if Apple messes something up when reinstalling IOS, they will give you a brand new phone for free.
There's literally nothing that you can mess up with reinstalling the OS.
PSU Tier List | CoC
https://linustechtips.com/topic/880876-iphone-8-issue/#findComment-10889659
I haven't ever done it. But if it is something wrong with the phone (though I don't know what hardware issue it could be) then Apple will just give you a new iPhone 8 for free.
https://linustechtips.com/topic/880876-iphone-8-issue/#findComment-10889669
They're still going to make him restore it first anyway (after making sure he didn't miss the setting), so he may as well try that before wasting time going to the Apple store.
PSU Tier List | CoC
https://linustechtips.com/topic/880876-iphone-8-issue/#findComment-10889678
I agree that he should try resetting it and change any setting he can to get it working, however, I wouldn't do anything that could have even a slight risk of permanently damaging his phone. All my opinion, do whatever you feel best.
https://linustechtips.com/topic/880876-iphone-8-issue/#findComment-10889695
