Hello,
I am planning of building a new pc because the one  I have now is,well,kind of dying and I would your opinion on some parts
Those which  I have selected are:
AMD CPU Ryzen 3 1200 (AM4/3.40 GHz/10 MB)
Sharkoon T3-W blue Midi Tower
Corsair Desktop RAM Vengeance 4GB 2400MHz DDR4
( 2x4gb)
WD Blue Desktop HDD 1 TB
but I am not sure,what do you think about the power supply and the gpu
Last but not least,what motherboard can support the cpu I have selected (doesnt need to be expensive)
BTW,the pc wont be anything extreme gaming thing,just,something it would be able to run the most basic games)
https://linustechtips.com/topic/880641-pc-parts/
I woUld hoghly reccomend an ssd thats low capacity. What is your budget and what will you do on your pc.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/880641-pc-parts/#findComment-10887317
14 minutes ago, ParianoShere said:
Hello,
( 2x4gb)
You just opened my mind up... I never New the gt1030 existed... I had a gt730 laying around and I thought they stopped then because I never saw a gt930 but yes this pc will be pretty good for basic games like csgo, Minecraft, fortnite, basic things of that manner
https://linustechtips.com/topic/880641-pc-parts/#findComment-10887341
I feel like nobody will really scold you for it.
what's your budget and what machine do you have currently?
if the budget is tight , you might be able to just fix or upgrade what you have as the machine you're purposing really wouldn't be worth building over getting something that is used but faster or a used prebuilt and adding a gpu.
https://linustechtips.com/topic/880641-pc-parts/#findComment-10887455
Well,my pc now is as I mentioned,not in a good shape:
Specifically
AMD Athlon 5350 CPU
4.00GB Single-Channel DDR3 (11-11-12-28) RAM
MSI AM1I (MS-7865) (P0) Motherboard
512MB ATI AMD Radeon HD 8400 / R3 Series (MSI) Graphics (which is in the CPU)
931GB TOSHIBA DT01ACA100 (SATA)
(the other parts are from my country so you wont know them)
my budget is about 580$
https://linustechtips.com/topic/880641-pc-parts/#findComment-10900991
