So I am planning on saving up for a computer, and I need your help. The budget is going to be $500 - $750. I will be earning the money by doing various things. My parents/grandparents might be able to pay for some of the parts. I would like you guys to pick out parts in that budget. Also give me suggestions too. One more thing, the case has to be the NZXT S340 or the NZXT S340 Elite. Color must be white. That's the only preference. Thanks!
https://linustechtips.com/topic/880442-help/
what are you going to be using the pc for?
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
https://linustechtips.com/topic/880442-help/#findComment-10885405
You must provide more information - what are you going to use for, is it really hot or real cold where you live where are you planning on putting it (carpet or something) also what time frame are you thinking about building this (next day/week or possibly in a month or two)
https://linustechtips.com/topic/880442-help/#findComment-10885417
Need info... 1- why "waste" so much of your budget in the case ? 2- what are you using it for ? Gaming i guess ?
https://linustechtips.com/topic/880442-help/#findComment-10885473
you can find the s340 for $30 - that's what I got mine for - and even spending 60-70 on it it , if it would make the system better for the end user I think it is worth it
https://linustechtips.com/topic/880442-help/#findComment-10885508
Oh sorry then ... I forgot that only in my country the s340 and s340 elite are expensive xD
https://linustechtips.com/topic/880442-help/#findComment-10885586
I am going to be using the PC for gaming, the games I will be playing are Battlefront II, Overwatch, PUBG, and Fortnite. Also I want the NZXT S340 because I like white cases. If you can suggest better white cases, I will take it. Also, I live in North New Jersey so right now its freezing in the winter but I have heat so its like around 70 degrees. I'm planning on putting the PC on a desk, and I have a wooden floor so yeah.
https://linustechtips.com/topic/880442-help/#findComment-10888433
CPU: AMD - Ryzen 5 1500X 3.5GHz Quad-Core Processor  ($169.99 @ SuperBiiz)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($60.98 @ Newegg)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($95.88 @ OutletPC)
Storage: Crucial - BX300 120GB 2.5" Solid State Drive  ($49.99 @ Amazon)
Storage: Toshiba - 1TB 3.5" 7200RPM Internal Hard Drive  ($42.19 @ OutletPC)
Video Card: Zotac - GeForce GTX 1060 6GB 6GB Mini Video Card  ($267.89 @ B&H)
Case: DIYPC - DIY-F2-W MicroATX Mini Tower Case  ($29.98 @ Newegg)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($21.98 @ Newegg)
Total: $738.88
Generated by PCPartPicker 2018-01-02 21:18 EST-0500
https://linustechtips.com/topic/880442-help/#findComment-10889528
  • 3 weeks later...
