LED Connection
Go to solution Solved by W-L,
5 hours ago, MathiasVO said:
Hey all :)
i recently got the Be Quiet Dark Base 700 case.
that case has LEDs built into it from the manufacturer, so i was thinking whether i'd be psosible to connect the case LEDs to my corsair node pro?
since the standard connectors dont seem to be compatible
thanks
No they can't be used together as the case has analog 4 pin RGB lights unless you replace all the LED's with addressable lights since that's what the Corsair node pro uses.
Hey all :)
thanks
https://linustechtips.com/topic/879839-led-connection/#findComment-10880940
