Hi just started Litecoin mining on my 780 with cudaminer I am wondering what a good pool to mine In would be right now I am using mine-litecoin but I'm not sure how good it is any suggestions for pools BTW I will likely not be doing this for very long just a week to a month to see how it works
https://linustechtips.com/topic/87918-litecoin-mining-beginner-questions/
I really wanna mine coins with my 7950. But with the current difficulty I am barely making a profit let alone earning back my power bill $$$. Is there any other alternative?
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
You can view a list of known pools and their share of the network here.
https://www.litecoinpool.org/pools
Try to avoid WeMineLTC, they are gaining to much of the overall hashrate.
Personally I use Liteguardian. I've also used LitecoinPool.org and LTCRabbit in the past.
You keep using that word. I do not think it means what you think it means.
Users cannot, and will not securely manage key material. Most users can't and the ones that can, wont.
Ask me about Bitcoin, Litecoin, Crypto-Currencies, and/or Mining them.
