I've been using a 950 for my rig for quite a while and for some reason these past few days my screen started glitching and freezing randomly when Im playing games and doing other stuff. I've tried to record it and it seems there's no problem on my video while my screen froze/glitched. Is it my screen or is it my 950 ?
https://linustechtips.com/topic/879020-display-problems-on-gtx-950/
Have you tried the usual stuff? Updating / reinstalling gpu driver, using a different monitor cable...
If you find any grammar or spelling errors please fill out entry permit A38, thanks.
Greetings from germany
Profilepicture by Chibiterasu-chan
Ya I did, and for some reason when i used HDMI my resolution just changed automatically to 1024x768 :/. I even tried recording my screen while gaming. Changing my VGA cable is also not making any change.
Edit : Also I tried dxdiag too and it shows thats nothing is unusual on my GTX 950 but Im still not sure.
Edited by Sta1n
Added details
13 hours ago, crosstiger said:
Do you have a second screen at hand for testing?
Uh nah but when I plugged my screen to my laptop through VGA it also had the same problem but it only happens occasionally and not as much as when I plugged it on my pc :/ sorry for my late reply
Then I would switch the monitor. Ask your family if you can borrow a monitor or take you pc to work / school.
Ok well I might just take it to a service center somewhere. And uh do you think a screen recorder will capture like any lag/graphics problem if I have a problem with my GPU ? I dont see any problems on any of my recordings so far while my screen froze.
22 hours ago, FluffaDuck said:
Ive had the same problem for a year... Any idea on fixing it?
When I plugged my old laptop to my screen it also froze up for some reason but I cant find any green screen whenever i plugged it in it still froze up and flickering tho
This does sound like a broken monitor. Only way to varify this is to use a different monitor.
