I am looking to upgrade my PC to do gaming and YouTube videos but I don't know what needs to be changed I think it's my CPU because it keeps hitting 100 percent usage. Need help. Looking at core i7 6700k.  price range up to $500. PC specs: Acer aspire t tc-220, and a10 7800 quad core processor, and radeon r7 340 2gb, 16 gb ddr3 ram.
https://linustechtips.com/topic/878911-help-with-upgrade/
Save up more, you will have to change most of it. Both GPU and CPU are trash
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/878911-help-with-upgrade/#findComment-10871485
is your budget in $USD or CAD ?
Photography / Finance / Gaming
https://linustechtips.com/topic/878911-help-with-upgrade/#findComment-10871501
just watching youtube vids or making them?
https://linustechtips.com/topic/878911-help-with-upgrade/#findComment-10871533
nothing but bad news man and upgrade makes your ram unuseable so even that needs to be changed your your looking at around
-about 300$ for CPU (i recommend a 1600x or 1700x) or 8700k if your gunna ball out 400$ i have a 6700k and it just isnt ment for streaming
-about 80-120$ for a mobo
-about 200$ for 16G of DDR4 RAM (DDR3 is out)
your gpu cant really hang unless your using 720p monitor from the dinosaur age so thats another
250-750$ just there i recommend a 1070ti for around 470$ for 1080p and 1440p and a good monitor to pair with it
youll probably need a new PSU a decent bronze 650W for a good brand really
cooler is your choice of air or water
id perfer water to add a thermal buffer and better heat dissipation and noise control
celsius S36 would be the best 360 rad imo
h100i V2 is a good 240 rad
and a 120 isnt really worth it imo
this is around 100-120$
just remember dont get a 360 if you cant fit it but more length is better cooling means quieter too
might as well get a case while your at it any one you like really but i recommend stuff like a cougar panzer good ventilation and everything is pretty much thought of aside from a verticle gpu mount
optional SSD if you dont want 5 minute boot times and perfer 17 second ones
this is what i would do for a content creator/gamer build everything heres is more than enough to get me started and  keep me relevent for 2-3 years and satisfied for 2-3 years maybe 4 years with some modesty
its just real hard to upgrade from that dinosaur to today so 500$ wont cut it. take it as advice from me
https://linustechtips.com/topic/878911-help-with-upgrade/#findComment-10871541
Damn thanks though I'll hold off half a year and put my budget up to something like $1500. It's just not a very old PC and runs most games really well. It was also a $1500 gift from my parents and I don't want to offend them.
https://linustechtips.com/topic/878911-help-with-upgrade/#findComment-10871581
$500 is more than enough for a competent upgrade.  Ryzen 3 1200, 16gb DDR4 ram, SSD, GTX 1050, and you're off to the races.  Your PSU *should* handle it fine (it's 300W max), and you can keep your case, HDD, accessories.
You'll be able to handle most games at 1080 high / ultra settings.  Video editing / processing will take a bit longer than a 7770k or Ryzen 7, but I doubt you're on a time-sensitive production schedule, lol...
https://pcpartpicker.com/list/VvtWM8
@Shifty345
Main Rig:
Case: Lian Li Lancool Mesh RGB
CPU: Ryzen 5 3600
Cooler: CoolerMaster MasterLiquid 240
MB: MSI B550 Gaming Pro Carbon
Ram: Gskill DDR4 3600 x 32GB
GPU: Asus Arez Strix Vega 64 OC
PS: Seasonic FOCUS Gold Plus Series SSR-750FX
SSD1: Crucial P1 1TB NVME
SSD2: Adata SU800 512gb M.2 Sata
HDD: Hitatchi 2tb 7200RPM + 3x 2TB WD Passport USB 3.0
Monitors: AOC C24G1
Keyboard: Cheap Blue Knockoff Mechanical
Mouse: Uhuru Gaming Mouse
OS: Pop! 21.04
Current Vintage Equipment:  Please ask me about it, I love to talk old tech!
IBM Thinkpad 390, IBM Aptiva A12, IBM PS/2 Model 25-004.  Compaq Contura 4/25C, Presario 7596
Asus P5A-B Socket 7 Box, Tandy 1000RLX-HD "B" & 1200-2FD, VIC20, Zenith ZFL-181-93, Packard Bell 300SX.
Apple II/gs, Mac Plus x2, Mac SE x2, Performa 450
https://linustechtips.com/topic/878911-help-with-upgrade/#findComment-10871582
3 minutes ago, Shifty345 said:
Making.
something like this is what i'd recommend, reuse the hdd, os and ram.
CPU Cooler: RAIJINTEK - AIDOS BLACK 48.6 CFM Sleeve Bearing CPU Cooler  ($12.99 @ SuperBiiz)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card  ($269.99 @ B&H)
Case: DIYPC - DIY-BG01 ATX Mid Tower Case  ($19.97 @ Newegg)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($22.98 @ Newegg)
Other: X79 board ($103.74)
Other: E5 2660 ($79.95)
Total: $509.62
Generated by PCPartPicker 2017-12-29 00:47 EST-0500
https://linustechtips.com/topic/878911-help-with-upgrade/#findComment-10871593
I just want it to run obs and a fairly low end game at once.
The machine I posted above will handle that no problem.  And you could re-sell your AMD card, and old mobo/cpu/ram combo to recoup $150 or so.
Main Rig:
CPU: Ryzen 5 3600
Monitors: AOC C24G1
OS: Pop! 21.04
https://linustechtips.com/topic/878911-help-with-upgrade/#findComment-10871596
