I am connecting to my desktop computer from my laptop. The Desktop computer (host) has a lower resolution display than my laptop and when I connect to it the maximum resolution I can stream it at is the maximum resolution of the host. This results in either a small window with black borders when connecting or if I scale to full screen it looks blurry and ugly. My question is can I use team viewer at a higher resolution than the host computers monitor. (My laptop display is 2160x1440 and the host computer is running at 1920x1080)
https://linustechtips.com/topic/878141-teamviewer-resolution-problem-help/
Teamviewer mirrors the host, sadly. You might want to look into VPN and RDP for the solution that you're looking for, or port forwarding port 3389 on your router and enabling remote access on your PC.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
Never, ever forward port 3389 or even port 5900 straight to the internet. Many of the cryptolocker attacks work by exploiting this port. This is an RDP / VNC port and if it is open hackers can relatively easily access your entire computer. Not worth it.
If you need to access ports outside of a network use a router with VPN capabilities.
Main Rig: https://uk.pcpartpicker.com/list/kLDFqk
Server: Dell PowerEdge R710 / Intel Xeon X5675 @ 3.06GHz / 128GB DDR3 RAM / Dual RAID 5 Arrays (3x 1TB + 3x 2TB) for 6TB of Storage
Laptop: HP Pavilion x360 13-s150sa / 13" 1080p Display / i5 6200u / 128GB SSD / 8GB DDR3 RAM
Broadband: Virgin Media Vivid 350 (385 Mbps Down / 20 Mbps Up)
