RAID 0 Help
1 hour ago, Crunchy Dragon said:RAID 0 gives you the space of both drives, but no higher speed. RAID 1 gives you redundancy in that if one drives fails, all your data is still stored on the second drive. RAID 5 does both.
RAID 5 requires three or more drives and is slower than RAID 1 (and obviously RAID 0) due to parity overhead.
@Rezalis If you want to put two drives into RAID, then you have two options, RAID 0 and RAID 1. RAID 0 will theoretically double the speed (but also double the risk of all data being lost) and give you the space of both drives in usable space. RAID 1, which will give you redundancy but will give you a total capacity of only one of the drives. Both require the drives to be formatted, so you would have to completely erase both drives and then reinstall the OS.
