Hi i just built my first pc and when i went to start it up only the LEDs on the ram stick lit up, nothing else. No fans no gpu, So i took it apart and checked to see if everything was plugged in and it was.So i tried again and again. Ive taken it apart multiple times. Can someone please tell me whats wrong with it or what it could be. Help would be highly appreciated.
 Heres the parts list of my build.        https://pcpartpicker.com/list/bx863F
https://linustechtips.com/topic/877285-please-help/
Do you want to say that no fans were spinning or not lighting up? If theyre not spinning up, maybe check if you have all cables plugged in that need to be. Do you have a 6pin connector plugged into your gpu? DO you have the 24 pin and 8pin cable attached to the motherboard? Check every cable
My Box of Fµn:
CPU - AMD Ryzen 5 1600
GPU - Gigabyte GeForce GTX 1080 Windforce
RAM - Corsair Vengeance LPX 16GB DDR4
MoBo - MSI B350 PC Mate
Case - Phanteks P400s Tempered Glass
PSU - BeQuiet 500W PurePower 10
Fans - BeQuiet PureWings 120mm x3; 140mm x2
Cooler - Corsair H100i v2
and THE POWER OF RGB
https://linustechtips.com/topic/877285-please-help/#findComment-10857723
Yes. i've checked every cable and i've plugged in every fan. Ive unplugged and plugged everything up 3 times and only the ram cards light up.
Just now, airdeano said:
are both the 8-pin and 24-pin plugs from the PSU plugged into the motherboard?
possible the motherboard doesn't support the RAM choice. (GPR432GB2400C15QC is supported not your GLB48GB2400C15DC in the QVL)
Yes. everything is plugged in
https://linustechtips.com/topic/877285-please-help/#findComment-10857740
do you have a monitor connected? Does your motherboard have any kind of error code display or debug leds that light up? If nothing helps go ahead and reset your bios /clear your cmos, maybe that helps
My Box of Fµn:
https://linustechtips.com/topic/877285-please-help/#findComment-10857752
Its connected but it has no signal.
then you have RAM issues or something else. im leaning RAM issues.
The motherboard recommends DDR4-2400 and my RAM stick are DDR4-2400
https://linustechtips.com/topic/877285-please-help/#findComment-10857820
