12 minutes ago, Sword_of_Truth said:
Hi there, my cpu died and i need a replacement, but i dont have the box, all i have is the cpu and whatever is written on it. Is there any way i can still get my warranty replacement with intel if i only have the cpu?, it is a boxed processor i bought
What happened, it overheated?
https://linustechtips.com/topic/876827-cpu-died-help-pleaseee/#findComment-10854260
Go here: https://supporttickets.intel.com/warrantyinfo?_ga=2.53093994.336979684.1514112876-1568636533.1514112847
You need to enter the FPO and ATPO , both of these can be found on the CPU itself. If you do not know how to find it enter you're cpu model enter your model number on this site and it will explain where they are located: https://www.intel.com/content/www/us/en/support/articles/000005609/processors.html
I then believe it will tell you more about your warranty coverage and how to request a RMA (i think).
They may also might want proof-of-purchase btw.
https://linustechtips.com/topic/876827-cpu-died-help-pleaseee/#findComment-10854338
Thank you for the links, you wouldnt believe it.. i entered the numbers and they dont work, they are the propper ones i even tried the last five digits of the atpo and it says my processor could not be located
https://linustechtips.com/topic/876827-cpu-died-help-pleaseee/#findComment-10854736
What does your cpu say on it?
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/876827-cpu-died-help-pleaseee/#findComment-10854794
