so my pc can easily run rainbow six sieges at medium settings and I can run 75 fps v sync and all that jazz but sometimes it stutters down to specifically to 57 fps then bounces back up to 75, and it really confuses me so i turn the settings down and turned off vsync and it did that but didn't help it just stayed at 57 without budging and i am confused
https://linustechtips.com/topic/876806-gpu-problems/
Rainbow Six Siege is not so much a demanding GPU game (okay, until you max out the settings) -- it's more of a CPU bound game.
What are your system specifications (e.g. what CPU, GPU, RAM, etc)??
(BTW, what's your Uplay username? I can add you for some R6 sesh...raking in 760 hrs on PC here :ph34r: )
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/876806-gpu-problems/#findComment-10854134
cpu: g4560
gpu evga gtx 1050
ram; 2400 1x8 gb
my ubisoft name is "theshube"
https://linustechtips.com/topic/876806-gpu-problems/#findComment-10855548
