Ram/Motherboard problem - PC won't post.
I just built my pc and it won't even start up at all.  Everything turns on, but nothing shows up on the monitor. I checked and the d ram LED is constantly on. I tried pressing the mem ok button and it changed to a blinking light. I've tried every single slot, using different ram sticks, just using one and nothing seems to work. I also tried with the motherboard out of the case with the bare minimum plugged in. I even tried without ram and it does the same thing, no beeping. Not sure what else I can try, I got the motherboard used, so I have no idea if I messed it up or it came they way. Sorry if the formatting is bad, I'm on mobile.
SPECS:
Motherboard: ASUS P8Z68-V PRO
CPU: Intel I5 3570
GPU: GTX 670 FTW 4GB
RAM:8GB DDR3 1333mhz  (2 4GB sticks)
PSU: Seasonic S12II 620 watt
https://linustechtips.com/topic/876235-rammotherboard-problem-pc-wont-post/
SPECS:
CPU: Intel I5 3570
What is your HDMI/Optical cable plugged into?
“The problem with the world is that the intelligent people are full of doubts, while the stupid ones are full of confidence.”
― Charles Bukowski
Desktop | Intel Core i5 - 7600k | ASUS Strix B250F | MSI GeForce GTX 1080Ti x Gaming 11G | 256GB Samsung Evo | x2 WD Blue 1TB | Corsair Vengeance LPX (2x8GB)
Mini Desktop | Mac Mini | Core i7 2.3GHz | 8GB RAM | 1TB HDD x2
Laptop | MacBook Pro 13in w/Touch bar (2016) | Intel Core i7 | 8GB LPDDR3 | 1TB SSD
Laptop | Lenovo Thinkpad Edge | Intel Core i5 | 16GB DDR3 | 256GB SSD
Peripherals | Razer Chroma Orbweaver | Magic Mouse 2 | Corsair K70 RGB | Logitech G402 | Blue Snowball | Logitech G922 | Logitech Artemis Spectrum G933
Galaxy Tab S2 - used as a media streamer, more often abused by my 1 year old son.
On 23/12/2017 at 1:56 AM, Skatanic241 said:
The GPU
Plug it into your motherboard. As you don't have the required display drivers installed for your GPU, that may be why you're not getting a display.
― Charles Bukowski
