I just recently purchased this vandal switch
https://www.amazon.com/gp/product/B01EUY612C/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
It did not come with any instruction on how to install it. I have looked online for similar switches and videos on how to actually install it on your mother board.
Any assistance would be greatly appreciated.
https://linustechtips.com/topic/876219-vandal-switch-help/
23 minutes ago, Maquali said:
So how would I install it to be used as a power switch for my computer? I am doing a custom in-desk pc build and need to power it on some how.
Drill the corresponding sized hole in the desk but slightly smaller then screw it in with the threads
CPU: Ryzen 1700@3.9ghz; GPU: EVGA 560 Ti 1gb; RAM: 16gb 2x8 Corsair Vengeance LPX DDR4-3000; PCPP: https://pcpartpicker.com/list/b3xzzM
https://linustechtips.com/topic/876219-vandal-switch-help/#findComment-10849453
This is a latching switch, you need a momentary switch for a PC power button.
Desktop: i9 11900k, 32GB DDR4, 4060 Ti 8GB 🙂
https://linustechtips.com/topic/876219-vandal-switch-help/#findComment-10849456
Is this due to the switch being in a "locked down position" and continuously triggering the power? Excuse my ignorance here, I am just trying to figure this out so I can get this set up the right way.
https://linustechtips.com/topic/876219-vandal-switch-help/#findComment-10849520
Yes that's what a latching switch is. If you press it in, it makes and holds the circuit until you press it again. A momentary switch only makes the circuit while you're holding the switch in. It does say that this switch will act as a momentary switch if you don't press is all the way, but what happens  when you DO press it all the way? It will probably cause you're computer to turn on and then immediately turn off.
https://linustechtips.com/topic/876219-vandal-switch-help/#findComment-10849602
1. It's Latching Switch, you want Momentary Switch(Link: https://www.amazon.com/Switch-Vandal-Resistant-Illuminated-Momentary-Housing/dp/B0039OCO9O/ref=sr_1_6?m=A3GO5VFCNOM5I7&s=merchant-items&ie=UTF8&qid=1514134764&sr=1-6&keywords=switch)
2. You usually have six pins (8 pins if it's RGB Switch). Pin one and Two are usually set to Normally Closed and Three and four are set to Normally Open. You want to use NO (Normally Open).
Current Build: Project Frost
Gaming Rig Build: Project Ice Dragon
https://linustechtips.com/topic/876219-vandal-switch-help/#findComment-10854985
