So i asked a couple times on this forum for help and no one knew the problem so i took it on my self to figure it out and help others who might not know whats wrong.
So if you playing Batman Arkham Origins on your VG248QE and you see these dark lines around each box or item when you look around, all you have to do is go to your monitor menu, Image, and tracefree. These lines only happen when your monitor is set to 100% trace free. If you put it to 0 though you will get terrible motion blur so i keep mine on 80 and everything is perfect. 60-80 is fine since the settings only go by 20.
Let me know if you need help or want pictures.
Again this is for ASUS monitors that have Tracefree option in the menu.
https://linustechtips.com/topic/87587-vg248qe-dark-lines-fix/
https://linustechtips.com/topic/87587-vg248qe-dark-lines-fix/#findComment-1187655
