My current board is a BioStar X370GTN, but for Christmas I got myself a new Gigabyte AX370 Gaming K3 along with a Corsair 570X.
I have a Ryzen 5 1600, currently with the stock cooler but I will be upgrading to an H100i v2 shortly as well. What is the normal overclock range for this chip? What's a safe BCLK, multiplier, and voltage to set it at?
https://linustechtips.com/topic/875692-overclocking-range-ryzen-5-1600/
DO NOT GET AN H100i THAT IS A WASTE OF MONEY! Get something mid range like a Cryorig H7 or a cheap 120mm liquid cooler and that's all you need for Ryzen 5. If you REALLY want to push voltage to its limits get a Cooler Master MasterLiquid 240 lite. You can get them for like $60 and it will let you push your CPU to its safe voltage limits (around 1.4 volts iirc). With a Ryzen 5 1600 you can expect to get somewhere in the neighborhood of 3.8-4.0 ghz. 3.9 seems to be the common limit for 1600 non x chips.
What clockspeeds can you get on the stock cooler? From what I hear most people get 3.7 on it, and I question whether or not spending ~$50 on an aftermarket cooler to get an extra 200 mhz is worth the money. However, it's your choice.
TL;DR: Don't get an H100i, it's a waste of money. Get a Cryorig H7 or MasterLiquid 240 Lite. You can expect to get 3.8-4.0ghz on a 1600.
Main System: EVGA GTX 1080 SC, i7 8700, 16GB DDR4 Corsair LPX 3000mhz CL15, Asus Z370 Prime A, Noctua NH D15, EVGA GQ 650W, Fractal Design Define R5, 2TB Seagate Barracuda, 500gb Samsung 850 Evo
Secondary System: EVGA GTX 780ti SC, i5 3570k @ 4.5ghz, 16gb DDR3 1600mhz, MSI Z77 G43, Noctua NH D15, EVGA GQ 650W, Fractal Design Define R4, 3TB WD Caviar Blue, 250gb Samsung 850 Evo
Dont touch BCLK first. It's a minor tweak to apply after the rest are set.
Voltage: Maximum 1.4V
Multiplier: Try 37 first, then increase by 1 if it passes stability test/stress test. If it fails, dial it back.
Desktop benching:
getting a cooler with a 1600 doesnt really make sense, you are looking at 3.7/3.8 vs 3.9
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
I just want it mainly for looks and for quietness. More cooling power means I can run the fans slower. Plus a 240mm liquid cooler will look hella dope in an all tempered glass 570X.
The h100i is really loud. You'll want to replace the fans.
Just now, byalexandr said:
And I will.
Keep in mind you're spending like 160 to have the PC look marginally better. If that's what you want, then fair enough, but for that cost you could afford a 1700x with a suitable cooler for it and get an extra 2 cores, which would. Give you an extra year or two out of your PC.
