Wireless vs. Bluetooth Mouse
Go to solution Solved by hconverse02,
One uses a usb port, the other doesn't.  There is little to no input lag difference between the two
What are the pros/cons of using bluetooth as opposed to usb wireless for the logitech mx master
Thanks!
Specs:
 Gaming PC: i5 3570, 16GB 1600MHz, GTX 780 3GB, Transcend 128GB, WD 500GB, Seagate 500GB, Thermaltake 600W Smart, S340 w/ RGB, Windows 10 Pro
 Server: Xeon E5 2650, 12GB 1600MHz ECC, 8400GS, WD 2TB + 1TB + 1TB, EVGA 500B 500W, Windows 10 Pro
 Laptop: Macbook Pro Retina 2013, i7 4558U, 8GB 1600MHz, Intel Iris Pro 1.5GB, Apple 256GB NVME, Mojave
 Internet: $70/month For 500/100, Actually get 525/102
https://linustechtips.com/topic/875442-wireless-vs-bluetooth-mouse/
