Hey everyone, I'm planning on making my first gaming pc in a few weeks and I've done some research but I'm still not confident in my judgment on whether or not I should buy the parts. I'm from the UK so I'm using £s and my budget is around £500 or less, I'd rather not go over. The computer will be mainly used for gaming but will also be used for light amounts of editing or creative work. At the moment I haven't got enough for a GPU but I'll be getting a 1060 3gb next mount or so. The image below is something that I've thought of getting but I'm not sure.
https://linustechtips.com/topic/875215-first-build/
7 minutes ago, Galactic Nebula said:
Kaby is dead and no one should buy it
should get a case with airflow
What games are you playing and at what resolution/refresh rate?
Probably want an R5 1600 + GPU, i5 8400 if you really need something now as it comes with an iGPU at least
Or wait for Raven Ridge APUs coming Q1 next year, no real news on that.
https://linustechtips.com/topic/875215-first-build/#findComment-10839900
Well I'd like to play games at 1080p and I don't really have a set genre of games I'd like to play, probably free roaming or shooters, maybe a game like destiny 2 or something like that. Also I would like to play 60 FPS or above as much as possible.
The case was something that I just decided the pick cause I wanted to see the full ish price of the build (excluding the GPU)
https://linustechtips.com/topic/875215-first-build/#findComment-10839959
What country are you in so I can put together a build?
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
https://linustechtips.com/topic/875215-first-build/#findComment-10839976
23 minutes ago, Galactic Nebula said:
I'm from the United kingdom and if you are going to build one, please keep it under £500 don't bother about a GPU I'll get one in a mouths time.
You basically picked the worst possible time to build a PC, as the i5 8400 is out of stock everywhere it looks like and Ryzen has no iGPU and DDR4 pricing sucks
https://uk.pcpartpicker.com/product/LHYWGX/intel-core-i5-8400-28ghz-6-core-processor-bx80684i58400
But at least your RX 570 pricing looks normal
So ya just save up a bit of cash and go R3 1200 + RX 570 most likely, or find a cheap used case/PSU/Hard drive maybe
The R3 1200 will be alright for 60hz gaming and the 570 alright for 1080p and AM4 lets you go up to 8 cores though you want a fan over your VRM at that point on that motherboard anyways
Ryzen+ is coming Q1 next year as well, likely a minor improvement over this gen
I'm also pretty sure the R3 1200 is reasonably close to the i5 7400 you had originally anyways, bottom video is Ryzen CPU performance scaling in games
And look for the reviews on the PSU, not sure if Jonnyguru has done one yet
PCPartPicker part list: https://uk.pcpartpicker.com/list/Ngvc3F
Price breakdown by merchant: https://uk.pcpartpicker.com/list/Ngvc3F/by_merchant/
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  (£88.99 @ Aria PC)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  (£73.33 @ CCL Computers)
Memory: G.Skill - Ripjaws 4 Series 8GB (2 x 4GB) DDR4-2800 Memory  (£73.39 @ Amazon UK)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£37.79 @ Aria PC)
Video Card: Gigabyte - Radeon RX 570 4GB Gaming 4G  Video Card  (£204.99 @ Amazon UK)
Case: Deepcool - TESSERACT SW ATX Mid Tower Case  (£24.99 @ Ebuyer)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£54.98 @ Novatech)
Total: £558.46
Generated by PCPartPicker 2017-12-19 21:55 GMT+0000
https://linustechtips.com/topic/875215-first-build/#findComment-10840053
6 minutes ago, Galactic Nebula said:
If you want a better CPU/Motherboard which is possibly a better choice for the long haul, then you can drop the GPU to the GT1030 which isn't too bad at 60GBP...it just won't run AAA games at higher settings, the 1050/RX 560(1024) are like twice as fast
Only issue is not knowing how Ryzen + is going to be....I'd maybe just wait entirely until Ryzen + is out and you have a higher budget for both the CPU and GPU...800 GBP ish?
PCPartPicker part list: https://uk.pcpartpicker.com/list/z4xjPs
Price breakdown by merchant: https://uk.pcpartpicker.com/list/z4xjPs/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (£169.99 @ Overclockers.co.uk)
Motherboard: Asus - PRIME X370-PRO ATX AM4 Motherboard  (£127.79 @ Aria PC)
Video Card: Asus - GeForce GT 1030 2GB Phoenix Fan OC Video Card  (£59.98 @ Ebuyer)
Total: £548.91
Generated by PCPartPicker 2017-12-19 22:05 GMT+0000
https://linustechtips.com/topic/875215-first-build/#findComment-10840080
future proofing.
3gb
I see an issue there
also an RX 5xx card will save you cash on Free-sync whenever you upgrade your display.
Really possibly just save your money until Ryzen + comes out get a larger budget and get a better CPU and GPU for your money
Or maybe the i5 8400 will be in stock before Ryzen +
You need a time machine.
https://linustechtips.com/topic/875215-first-build/#findComment-10840118
