Just now, Crunchy Dragon said:
Look into a used Ryzen or Intel CPU/RAM/Mobo combo
hey its you! xD. so that combo i have is good or? like i said before i really am iffy about ryzen even tho there is plenty of reviews about how good there are for the price for gaming.
https://linustechtips.com/topic/875198-help/page/2/#findComment-10856350
11 minutes ago, Alphabet said:
i have roughly 300$ to spend on a good cpu and mobo with ram. i was wondering if that would suffice
a ryzen 1600+AB350M and 8gb of ddr4 will push you somewhat over, you can sell off your old parts to make up for it.
the 7500 will choke in heavier scenes at 144hz, the 1600 would be much better.
https://linustechtips.com/topic/875198-help/page/2/#findComment-10856351
Just now, Alphabet said:
im just trying to figure out what the best mobo,cpu and ram i can get with 300$ or so. i really wanna stick with intel.
Shop around on your local craigslist and see what comes up, if prices seem a bit high for older generation hardware try and talk the seller down, and if they for some reason don't change their price, it's not worth it.
https://linustechtips.com/topic/875198-help/page/2/#findComment-10856360
see i tried craigslist and everyone selling computer stuff is far away from me lol
https://linustechtips.com/topic/875198-help/page/2/#findComment-10856363
the kabylake i5s lower-core count and lack of hyperthreading will cause it to have fps drops and stuttering with a 1070 on 144hz 1080p, the 1600 easily holds out with the extra 2 cores+HT. if you realy want intel then wait will H310 boards get released and get an 8400+H310 board.
https://linustechtips.com/topic/875198-help/page/2/#findComment-10856365
could i stream games like csgo and h1z1 that arnt to intense and still get good fps? could i even get a good ryzen chip, mobo, and ram for 300$?
https://linustechtips.com/topic/875198-help/page/2/#findComment-10856412
it should able to stream them just fine, it'll cost around $40 over for a cheap B350+1600 and 8gb of ram.
https://linustechtips.com/topic/875198-help/page/2/#findComment-10856414
25 minutes ago, Alphabet said:
is ddr4 ram even worth it?
you'll need it if you're going for a new cpu, no arguing about that.
https://linustechtips.com/topic/875198-help/page/2/#findComment-10856470
2 minutes ago, Alphabet said:
ok thanks. so what would u do if u were in my postion. trying to buy the parts by friday. ryzen or intel cpu,mobo, and ram for $300?
1600+AB350M, Intel only has Z370 boards right now which will cost more.
https://linustechtips.com/topic/875198-help/page/2/#findComment-10856484
it's just the same thing clocked slightly higher and without a stock cooler, no point since you can oc the 1600 anyways.
https://linustechtips.com/topic/875198-help/page/2/#findComment-10856593
