Nope. What are your processes in the background?
Current Build:
CPU: Ryzen 7 5800X3D
GPU: RTX 3080 Ti FE
RAM: 32GB G.Skill Trident Z CL16 3200 MHz
Mobo: Asus Tuf X570 Plus Wifi
CPU Cooler: NZXT Kraken X53
PSU: EVGA G6 Supernova 850
Case: NZXT S340 Elite
Current Laptop:
Model: Asus ROG Zephyrus G14
CPU: Ryzen 9 5900HS
GPU: RTX 3060
RAM: 16GB @3200 MHz
Old PC:
CPU: Intel i7 8700K @4.9 GHz/1.315v
Mobo: Asus Prime Z370-A
https://linustechtips.com/topic/874689-idle-cpu-usage-anomaly/#findComment-10835144
Something is going on, next time it happens go over to the processes tab, sort by CPU and see what is actually using it. Note it is not unusual for some background processes to run when you think you're doing nothing.
https://linustechtips.com/topic/874689-idle-cpu-usage-anomaly/#findComment-10835145
What's your security like? maybe a bot net or something could have been installed on your rig, runs in the background performing the acts of the evil!
I would checks check all of the processes, maybe download a tool like glasswire or tinywall to rule out something like that.
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
https://linustechtips.com/topic/874689-idle-cpu-usage-anomaly/#findComment-10835171
  • 3 weeks later...
