I'm planning on building the budget e-sports gaming PC:
CPU: Pentium g4560
GPU:gt 1030
Ram: 8GB ddr4
PSU: 400W 80plus
My only problem is that about the ground 1030 I don't know if I buy the passive cooling option or the active one, I don't know Wich one is better.
Hi, I am from Brazil and I pretend on building a Ryzen 2200G build. (to convert to Brazil's currency look up <your currcency> to BRL)
https://linustechtips.com/topic/874688-passive-x-active-cooling/
CPU: Pentium g4560
GPU:gt 1030
Ram: 8GB ddr4
PSU: 400W 80plus
Why do you go for the 1030 and not a 1050 which costs maybe $40 more or a used gtx960 which are better graphics cards?
Desktop
CPUi5-6600K MotherboardGigabyte GA-Z170-HD3P CPU Cooler: Thermalright True Spirit 120M Black/white RAM: Corsair Vengeance LPX 16 GB DDR4 2400Mhz GPU: Gigabyte 1070 HDDs: 2 x Seagate Barracuda 2TB 7200 RPM  SSDSamsung EVO 850 500GB PSU: Coolermaster 550W 80+ Gold Case: NZXT S340 (White) with a white led strip ;)
Laptops
Dell 7577
CPUi7 7700HQ RAM: 16 GB DDR4 2400Mhz GPU: GTX1060 Max-q HDD: 1TB 5400 RPM  SSDNVMe 512GB SCREEN: 4k IPS 15.6"
Macbook pro 2018
CPUi7 RAM: 16 GB DDR4 2400Mhz GPU: Radeon Pro 555X 4GB Storage256GB SCREEN: 15"
  • 4 weeks later...
Because I'm Brazilian and the gtx 1050 costs R$700 maximum and the gtx 1030 costs R$450 maximum. ;-;
It doesn't really matter, if you're short on money why not go for the used market? :
https://produto.mercadolivre.com.br/MLB-953268517-placa-de-video-zotac-geforce-gtx-960-2gbgddr5128seminova-_JM
Personal Desktop":
Luna, the temporary Desktop:
