hello before i purchase this cooler im wondering if anyone has it and if they have installed a different fan onto the cooler i wanted to get a Noctua NF-A15 HS-PWM fan it has the same mounting holes but its 2 times the thickness has anyone put a 25mm thick fan on it?  I just cant find anything on it haha
CPU: AMD Ryzen 9 5900HX GPU: AMD RX 6800M RAM: 16GB  SSD: 500GB NVME
https://linustechtips.com/topic/874600-cryorig-c1-help-please/
3 minutes ago, Sierra Fox said:
I have the C1 and put a Corsair ML120 on it, it comes with regular screws for normal thickness fans.
SWEET! thanks man i contacted cryorig and they said i would need some clamps or something lol you rock dude
https://linustechtips.com/topic/874600-cryorig-c1-help-please/#findComment-10834194
