USB C Hub
Go to solution Solved by Crunchy Dragon,
1 minute ago, SCGazelle said:
er.. here's the thing. That USB C Port is just a 'DC In' power passthrough to charge the laptop.
  Reveal hidden contents
I don't need that. I need that USB C port to be a full data and power passthrough out of the laptop and into my phone (basically a reverse of that image). I'm starting to think that there is some technical or standards limitation with that because every USB C hub has similar limitations to that one. Maybe I'll have to go for a more expensive and less portable Thunderbolt 3 option.
Yeah sorry, I realized that and made the appropriate edit to my previous post. I don't think you'll be able to find something like that outside of Thunderbolt 3
Hi! I've been looking for a USB C Hub that has a full USB C port that acts as a passthrough from my XPS to my phone and I can't find one. The reason I am looking for this is because I charge my Nexus 6P mainly from the USB C port on my XPS which fast charges it so I only need one charger. But all of the USB C Hubs I've found only have one USB C that is just a power passthrough to charge the laptop. Any ideas of where I can find one that can do this? The other ports I need are 3 USB A, HDMI, and Ethernet. Thanks!
https://linustechtips.com/topic/874495-usb-c-hub/
So you're looking for something like this? https://www.amazon.com/HooToo-Ethernet-Delivery-Network-Adapter/dp/B075KQZ45F/ref=sr_1_2_sspa?s=pc&ie=UTF8&qid=1513552914&sr=1-2-spons&keywords=usb+type+c+hub&psc=1
EDIT: disregard this, just realized there's no data transfer via type c
https://linustechtips.com/topic/874495-usb-c-hub/#findComment-10833197
Edited by SCGazelle
https://linustechtips.com/topic/874495-usb-c-hub/#findComment-10833211
https://linustechtips.com/topic/874495-usb-c-hub/#findComment-10833216
