power options
Solved by LogicalDrm,
1 hour ago, Walt said:Do you advise me to put it on? I use my pc for gaming and video editing. Will it give me more fps etc.?
That setting is more important when you are with laptop or some other mainly battery operated device. Then changing power plan and stuff makes more sense. On desktop it should be on high performance. It will prioritize CPU use and maybe use bit more electricity. But overall its better.
