H80i how exactly does it mount?
Solved by Thecrazyswede,
nothing I am not building yet I plan to get one and I wanted to know if I would need to open the back and install a backplate then screw it from the front for socket 1150
oh, yeah you will have to fit the backplate, otherwise it will not secure the pump head
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases7 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning21
play_circle_filled
Latest From ShortCircuit:
