Almost everyday, when I first time turn on my computer, it will say cannot read my disk. Also,  it takes 1 mins to load into desktop everyday’s first try,and the second time to turn on the computer is 15 sec(restart or turn off and then turn on all very fast) . Sometimes it saids cannot read the disk in the first try. There are never be a problem on second try of turning on my computer!! This is weird!!
https://linustechtips.com/topic/873685-help-computer-always-error/
5 hours ago, Skym said:
What is Bios Boot config?
BIOS options that affect which device your system boots from first.
Sometimes they can be set to something that doesn't boot, like a USB stick, but then will eventually skip it and go to the next drive.
You usually hit F12 F1 or DEL to get into the BIOS.
