So i choose most of my stuff... I have a Gigabyte R9 270X OC 2GB DDR5 Vram. So the overclocked version is selling at the see price as the normal one.
The question is what case would hold this card? I have a mATX mobo. And AMD Athlon 4X 750K. 4GB Corsair Vangance ram. And i will run the stuck cooling.
So i like the corsair 200r but it is kinda expensive. I have no leftover money so it would be nice to have something cheaper. Also i am in Hungary so not that much cases come here.
Thanks for your help.
Intel core I5 4460, Gigabyte H97M-HD3, Gigabyte gtx 760, 8 GB corsair value ram, Thermaltake core v21, Thermaltake Smart 630W PSU
Alcatel OneTouch D5... IT WORKS!!
http://pcpartpicker.com/p/BxMjTW
https://linustechtips.com/topic/87367-what-case/
Uhm can anyone reply? please... It would be a lifesaver....
https://linustechtips.com/topic/87367-what-case/#findComment-1185038
How much is cheaper, under 50 pounds?
CPU: Phenom 1090T, Motherboard: Gigabyte 78LMT-USB3 RAM: Generic 8GB 1600MHz GPU: MSI Radeon R9 270 HDDs: 2 Scavenged 160GB drives (I lost my 500GB one and I don't know how) SSD: Samsung 840 evo120GB  OS: Windows 7 Case: Bitfenix merc beta PSU: Corsair CX 600W
https://linustechtips.com/topic/87367-what-case/#findComment-1185041
Something from thermaltake, maybe cooler master 430, also zalman and aerocool have cheap cases.
all of these look suitable, you just don't get that much cable management
https://linustechtips.com/topic/87367-what-case/#findComment-1185064
Thermaltake has one that i like. The commander GS-II. Thanks for the help.
https://linustechtips.com/topic/87367-what-case/#findComment-1185072
I know. Next year i will update my case. So it will be used for a year or so. Thanks for the help.
https://linustechtips.com/topic/87367-what-case/#findComment-1185074
for now, just get something with front fan mounts and usb 3.0 support. also, make sure that it has reasonable wiring options
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/87367-what-case/#findComment-1185165
No need for usb 3... My motherboard won't support it. I'll change that first tough. none of the cases under 50 have any holes for cables. So i will ditch it and found the best one that could be used.
https://linustechtips.com/topic/87367-what-case/#findComment-1185296
Fractal Design Core 1000
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/87367-what-case/#findComment-1185365
around 50$. Would be optional.
Coolermaster N200.
https://linustechtips.com/topic/87367-what-case/#findComment-1185665
