Help With Dual Display
By
Guest
in Displays
in Displays
Solved by Oshino Shinobu,
1 minute ago, lewdicrous said:GPU: GTX 1070
CPU: i7-6700
Motherboard: Gigabyte H170
Go into the BIOS and check for an option to enable the iGPU, sometimes it's disabled when there's a dGPU in the system.
If not, a simple DVI to HDMI or DP to HDMI adaptor will work from the GPU
1
toxic_worper ·
5
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
1
Vibora ·
Posted in New Builds and Planning6
