so i wanted to use WOL to wake my pc automatically when i get home.
and that part works.
but now its virtually impossible to get it to sleep.
something wakes the system just moments after putting to sleep.
"powercfg -lastwake" just tells me its woking by the Intel Ethernet Adapter
how can i find out who sending the WOL package or what else might be triggering it?
"You know it'll clock down as soon as it hits 40°C, right?" - "Yeah ... but it doesnt hit 40°C ... ever  😄"
GPU: MSI GTX1080 Ti Aero @ 2 GHz (watercooled) CPU: Ryzen 5600X (watercooled) RAM: 32GB 3600Mhz Corsair LPX MB: Gigabyte B550i PSU: Corsair SF750 Case: Hyte Revolt 3
https://linustechtips.com/topic/873582-wake-on-lan-issue/
3 hours ago, yummiesttag said:
I have used Wake-on-LAN Packet sniffer from apreltech and it worked well.
https://www.apreltech.com/Free/Wake_on_lan_Packet_Sniffer
thanks thats a start now only to find out why microsoft azure is sending magic pakets
https://linustechtips.com/topic/873582-wake-on-lan-issue/#findComment-10826640
I had my nic set for wake on lan and had the same issue of it constantly turning on and azure was also sending them to me as well. So I just gave up on the wake on lan.
https://linustechtips.com/topic/873582-wake-on-lan-issue/#findComment-10827411
