Hello, everyone im planning to build a pc this christmas and here are my parts.
https://pcpartpicker.com/list/mrwYyf
I am new to building a pc and dont know much thing. Please see if these parts are compatible with each other. Also i will be running this at a 1080p monitor. I care about the look and i dont want wires tangled all over the place when i built it. I am planning to use this pc mainly for gaming and personal use for documents.
https://linustechtips.com/topic/873491-need-help-with-new-pc-build/
what is the maximum budget of the PC?
so i believed you have the monitor and keyboard and mouse
why are you using the i5 6600K?
the GPU you picked is not powerful for 1080P High details gaming
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
CPU: since you're already getting a Z270 motherboard, which is for Kaby Lake CPUs, I suggest you also get a Kaby Lake CPU (either a 7600K or a 7700K). From PCPP pricing the 7600K is even cheaper than the 6600K
PSU: Looking at ONLY the PSU Tier List, the PSU you got is Tier 4. IIRC, Tier 1 up to Tier 3 is recommended if you're going to be overclocking.
See this thread:
GPU: what games will you be playing? a 1050Ti isn't exacty a balanced pick against a 7700K. But if this is just a temp card which you plan to replace later, carry on. Otherwise I would recommend something along the lines of a GTX1060 or an RX580 for 1080p 60FPS gaming.
Karamo
CPU: AMD Ryzen™ 5 3600 | CPU Cooler: Wraith Stealth | GPU: Gigabgyte AORUS GeForce RTX 2070 Super | Motherboard: MSI B450M Mortar Max | RAM: G.Skill FlareX 2x8GB 3200MHz CL16 | SSD: ADATA XPG SX6000 Pro M.2 256GB | HDD: 1TB 2.5" Western Digital Blue (WD10SPZX) | Case: NZXT H510 | OS: Windows 10 Pro 64-bit |
try this instead, much better:
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($199.89 @ OutletPC)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($73.98 @ Newegg)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($92.88 @ OutletPC)
Storage: SanDisk - Ultra 3D 250GB 2.5" Solid State Drive  ($79.99 @ B&H)
Video Card: EVGA - GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($409.99 @ B&H)
Case: Cooler Master - MasterBox MB600L ATX Mid Tower Case  ($31.98 @ Newegg)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($23.98 @ Newegg)
Total: $912.69
Generated by PCPartPicker 2017-12-15 03:11 EST-0500
PCPartPicker part list: https://pcpartpicker.com/list/zKMCsJ
Price breakdown by merchant: https://pcpartpicker.com/list/zKMCsJ/by_merchant/
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor  ($279.99 @ B&H)
CPU Cooler: Deepcool - GAMMAXX 400 74.3 CFM CPU Cooler  ($23.49 @ OutletPC)
Motherboard: Gigabyte - Z370 AORUS GAMING WIFI (rev. 1.0) ATX LGA1151 Motherboard  ($102.98 @ Newegg)
Memory: Crucial - Ballistix Sport LT 8GB (1 x 8GB) DDR4-2400 Memory  ($81.99 @ Amazon)
Storage: ADATA - Premier Pro SP920 128GB 2.5" Solid State Drive  ($57.99 @ Amazon)
Video Card: NVIDIA - GeForce GTX 1070 8GB Video Card  ($399.99 @ Best Buy)
Total: $1002.39
Generated by PCPartPicker 2017-12-15 03:28 EST-0500
this or what @herman mcpootis posted, this will perform better but is abother $80
Builds:
My maximum budget is 900.
Yes i do have the monitor, keyboard and mouse.
Im using 6600k because i heard its good for entry lvl?
That GPU is just there to fill the gap, im planning to upgrade it soon.
See this thread:
Thank you for the guide.
If the 7600k or 7700k is the same price but better performance than 6600k then i change my cpu.
And yes i know 1050 ti is not that good, i plan on replacing it. Its just there to fill the gap.
Total: $912.69
Hello, there! And thanks for giving me a build idea. But the reason i picked most of the parts is that i lived in Norway and some of the parts that can be bought in America is not available here.
But i will try if those parts are available here.
