it doesnt even post
So there isn't even a error code on the debug display in the top right corner of the motherboard?
If you have the PC assembled in a case try pulling it out, and asseble it on a non-conductive surface. Something might be shorting out the motherboard
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/87329-need-help/#findComment-1184727
