dual monitor won't work
Solved by Tcrumpen,
Just now, budgetguy said:my friend is trying to hook up 2 monitors but it won't work.
he has gtx1060 and 1 dp and 1hdmi screen and they work alone but not togther
help pls
tnx in advance
Are the monitors the same make and model?
Also have you checked that the graphics card can use both HDMI and DP together, some graphics cards disable a output port when another is used due to compatibility issues; guessing the graphics drivers are upto date yes?
