How to add more IP addresses to a network (or maybe that isn't the problem)
Solved by Lurick,
5 minutes ago, WhisperingKnickers said:Strictly modem and router
Yah, I saw your edit.
I would have checked the router next and looked at the DHCP scope. Even though you have a subnet mask allowing for 254 devices, there is the ability, usually, to only use a part of that block for DHCP and have the other portion reserved. I would check and see if that's the case and if so, increase the block for DHCP allocation.
