Help needed with build!
Go to solution Solved by WoodenMarker,
Yeah, I'll probably buy from there, will they have the christmas sales (After christmas lots of prices go down)?
Thanks to @WoodenMarker and everyone else who helped me with this topic  :)
Glad to help. B)
I'm pretty sure they'll have sales but I don't know if that display will be on it.
Hi,
         I have a 5 year old laptop (Sony VGN series) and am looking to replace it? I have looked at priced up many different components (Using Linus Tech Tips YouTube and amazon.co.uk) It would be amzing if one of you guys could help me improve the list? I would use the rig for video rendering and a little gaming e.g. battlefield 4 in ultra settings,
The List:
  Case- Cooler Master Storm Stryker (White)
  Fans- Sickelflow 120mm RED LED
  Lighting- Dual 12” Cold Cathodes Red
  CPU- Intel i7-4771
  CPU Cooler- Noctua NH-U14s
  Motherboard- ASUS Maximus VI Formula
  CPU OC- Overclock CPU To Max
  Tuning Protection Intel
  GPU OC- Overclock GPU’s To Max
  RAM- Kingston HyperX Beast 32GB DDR3 2400MHz
  RAM Cooler- Black Kingston HyperX
  SSD- Corsair 240GB SSD [Act as boot drive & store programs on it]
  HDD- Western Digital 4TB WD4003FZEX HDD (File Storage)
  HDD Cooler- Internal Fan
  Optical Drive- ASUS BC-12DST (3D Blu-Ray)
  GPU 1- EVGA GTX 770 4GB SC w/ ACX  SLI
  GPU 2- EVGA GTX 770 4GB SC w/ ACX  SLI
  Power Supply- EVGA Supernova 1300w Modular Power Supply [80+ Gold Award]
  OS- Windows 8.1 Pro 64bit  [Already have disc]
  WiFi- Motherboard On-board WiFi
  Fan Controller- Case has built in fan controller
  Card Reader- Good all in one card reader needed for SD and USB 3.0(Akasa maybe?)
  Keyboard- SteelSeries Apex
  Monitor- Asus VG278HE
Any help will be much appreciated,
Relwof  :)
https://linustechtips.com/topic/87283-help-needed-with-build/
Don't see antyrhing wrong with it, but what's the socket on the MOBO?
CPU: FX-8350, GPU: xfx radeon r9 290, RAM: corsair venegance 8gb, STORAGE; seagate barracuda 1TB hdd, SSDnow kingston 120gb, CPU COOLER: CM hyper 212 , CASE: fractal design XL, PSU: corsair CS 650w 80+ gold MOBO: Gigabyte GA-990FXA-UD3
https://linustechtips.com/topic/87283-help-needed-with-build/#findComment-1183952
here we have a specific section to help you
http://linustechtips.com/main/forum/18-new-builds-and-planning/
------------------------------------------------------I HAZ SHINY----------------------------------------------------------
https://linustechtips.com/topic/87283-help-needed-with-build/#findComment-1183961
Thanks for all your replies!
                                          Would it be worth changing to a 4770K? I have never overclocked a PC before, I didn't really want to oc anything as I was told that is shortens life span of CPU etc?
https://linustechtips.com/topic/87283-help-needed-with-build/#findComment-1184026
Not worth going i7 for gaming. You should oc. Even though adding extra voltage will shorten the cpu's life span, it will likely still last longer than you need it to and setting your own voltage is often lower than the auto that adds more than needed.
If the 1300w power supply is too much can anyone recommend any different high quality power supplies? 750w-850w?
A decent 750w would be plenty.
Are you just shopping from Amazon or are you okay with other UK shops? Budget?
Why a 144 hz display? Also, why a 27" 1080p display? The pixels get quite large at that size.
What kind of videos are you rendering? Programs being used?
You need to quote a post or tag a member or else they won't get a notification you replied to them.
Build looks much overkill btw. You could go much cheaper.
https://linustechtips.com/topic/87283-help-needed-with-build/#findComment-1187737
I need the pc to last for about 7 years and be fast for the 7 years. I can shop from any store that ships to the UK, my budget is around £2000 or $3200. I use a few different programs that can use GPU to render so thats the 2 770's. Thanks for the tip about quoting-Im new to forums etc.
Please could you explain how I could go cheaper?
https://linustechtips.com/topic/87283-help-needed-with-build/#findComment-1194660
Look back at even a high end pc 7 years ago. It doesn't really matter what you get today as it won't be considered faster anymore even in 4-5 years.
What are you rendering? Programs being used?
https://linustechtips.com/topic/87283-help-needed-with-build/#findComment-1195842
I'll be using Sony vegas 12 Pro, Adobe elements, photoshop and after effects. I like to be on the internet and listen to windows media player at the same time, I plan to run Crysis 3, Far Cry 3 and BF 4 on ultra settings and use a ASUS VG248QE monitor with a DVI (If anyone can help choosing a Dual link DVI?)
https://linustechtips.com/topic/87283-help-needed-with-build/#findComment-1197412
You didn't answer my earlier question. Why a 144 hz display? Also, why a 27" 1080p display?
https://linustechtips.com/topic/87283-help-needed-with-build/#findComment-1197475
I have been looking into the display stuff and have decided to go with a asus vg248qe, I would have the 144Hz because I may buy the Nvidia Vision 2 Kit later in the year, the 1080p display is a must for me as I can tell the difference between 720p and 1080p. The 24"version will fit on my desk better too.
https://linustechtips.com/topic/87283-help-needed-with-build/#findComment-1198865
Have you considered getting a nice IPS panel instead?
https://linustechtips.com/topic/87283-help-needed-with-build/#findComment-1201877
I was considering the ASUS VG248QE, BenQ xl2420t and the ASUS MX239H and IPS panel. I have used monitors before where I could see ghosting so I thought I'd try to get a monitor with minimal ghosting. I looked at reviews for the ASUS MX239H and saw that it had lots of ghosting? I need a 23-24" panel that will look decent and come below £300 ($490) I do not need speakers, just at least at 1080p display.
https://linustechtips.com/topic/87283-help-needed-with-build/#findComment-1218560
What monitors have you used?
I've never really had ghosting problems with an IPS panel before.
https://linustechtips.com/topic/87283-help-needed-with-build/#findComment-1218567
I can't, last year I went to a tech event and I looked at some panels and I could see ghosting in the IPS range
If you're sensitive to it, the XL2420TE is basically the only high frequency panel I'd recommend.
I'm not sure if it's available in the UK and I've read it's going under the guise of the XL2420T and which one you get depends on your luck but I think this might be it. http://www.overclockers.co.uk/showproduct.php?prodid=MO-088-BQ
https://linustechtips.com/topic/87283-help-needed-with-build/#findComment-1218640
Yeah I looked for the BenQ XL2420TE but I could not find it on amazon.co.uk or currys etc? If i can get it off http://www.overclockers.co.uk/showproduct.php?prodid=MO-088-BQ that would be great, I am very cautious when buying online? I'm guessing overclockers is a good website that I can trust with my banking details?
https://linustechtips.com/topic/87283-help-needed-with-build/#findComment-1218666
They are trustworthy. I'm just wondering whether it's really the XL2420TE and not the XL2420T but the rev 2.0 label assures me a bit.
It'd be nice if someone could confirm this though.
https://linustechtips.com/topic/87283-help-needed-with-build/#findComment-1218689
https://linustechtips.com/topic/87283-help-needed-with-build/#findComment-1218777
