So I went to boot up my PC this morning and I couldn't boot up past the rog UEFI menu. I tried several times and couldn't get into even the bios. Well, I saw I was getting an A2 postcode, which is IDE Detect code. I only use 2 drives, an 850 pro and a 950 pro. Well, I saw some Asus forums saying it was a bad OC error menu. So I went in and changed some numbers on my OC and reset them, didn't save any settings, then I was able to boot into windows. So now that I'm in, I checked a few things and somehow I have an extra drive?
Here's Samsung magician showing and device manager, but nothing in windows?
https://imgur.com/a/kuyr3
Anyone got any idea what this drive is? I'm currently running a pc scan in case it's a virus.
Edit: Refreshed hardware changes and the drive went away, also still running scanner.
https://linustechtips.com/topic/872770-invisible-drive-device/
Well checking now, my original image post, my optical drive wasn't listed, but now it is. Both the random drive and my optical drive take-up bus1, but Samsung still shows this 3rd drive being there, and it normally doesn't pick up my optical drive as an option, unless I just need to reset windows.
https://linustechtips.com/topic/872770-invisible-drive-device/#findComment-10817872
