Hello, I was wondering if someone can help me make a budget build. I live in the US, price range is roughly $800-1200. I am looking to play games like PUBG, Fortnite, BF1, Star wars, and others. I am not too sure about resolution and such but I was think 1080p at 120hz with a good refresh rate. Also I am looking to go the intel route and I will need peripherals. Hopefully someone can tell me what is good and bad or even give advice on the things I mentioned.
Thanks in advance!
https://linustechtips.com/topic/871293-first-buildbudget-pc-help/
120hz at that price range might be a bit hard but I'll have to check. Youre going to have to stick with TN panels though.
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
Maybe 100hz then? I'm just looking for something that'll be good and last a long time, a good gaming experience with good quality visuals
Thanks in advance!
Does the $1200 include peripherals etc?
Case: Lian-Li PC-011 Dynamic  CPUi7-7700k (4.8ghz) CPU Cooler: Corsair H100i V2 Case Fans: 5x ML120 RGB / 2x LL120  GPU: Aorus RTX 2080 Xtreme Motherboard: ASUS ROG STRIX Z270H RAM: 32GB Corsair Vengeance RGB Pro DDR4 (3200mhz) Storage: 2x 1TB SG Barracuda, 128gb BiWin M.2 SSD PSU: Corsair RM650x OS: Windows 10
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
Just now, QuantumBit said:
I was not sure if this was part of the same budget
17 minutes ago, Brooksie359 said:
https://pcpartpicker.com/list/fHb3KZ this is what I came up with.
There's no storage or peripherals and @ 2.8GHz non-OC that's going to be a downer.
I was attempting a list, but after adding items down all the way to PSU, found that $1100 not including OS / Monitor / Peripherals this was going to be a challenge.
Nice try though, this is a tough one.
AsRock X99 Taichi MB // Intel Core i7-6800k Overclocked @ 4.0GHZ // Noctua NH-U14S Cooler // Corsair Vengeance LPX 16GB DDR4 // EVGA GeForce 980Ti SC+ // Samsung 850 EVO 500GB SSD // 2TB WD Gold HDD // Corsair RM850 PSU // Corsair Obsidian Series 750D // Asus VG248QE 144Hz
GIGABYTE GA-Z77X-UD5H LGA 1155 Intel Z77 // Intel Core i5-3570k Overclocked @ 4.2GHZ // Noctua NH-L9x65 Cooler // Corsair Vengeance 16GB DDR3 // EVGA GeForce 960 // 250 GB WD Blue HDD // EVGA SuperNOVA 650 G3, 80+ GOLD // Corsair Carbide Series 100R
https://pcpartpicker.com/list/v4hfJV ok now it has storage. but anyways the i5 8400 is a really good cpu and boosts to 4ghz so I would say is more than enough. if you look at gaming benchmarks it is clear that it wont bottleneck a 1070 in most use cases.
https://pcpartpicker.com/list/gqX87h
4 Cores, Higher Clock speeds are generally better for gaming, saves some money to use elsewhere.
The case is as you'd expect, cheap, but works.
16GB of RAM which I consider bare minimum for these days.
144Hz monitor
Cheap mouse, cheap keyboard.
This kind of a budget is hard, when you need EVERYTHING and want to game 100Hz+
No OS
Good Luck.
144Hz monitor
No OS
Good Luck.
look at gaming benchmarks and will realize that isn't really true.
My apologies, I didn't actually realize it boosted to 4GHz.
This budget is just difficult when you need a complete system.
144Hz monitor
No OS
Good Luck.
ok so your build is quite unbalanced. you are pairing a i5 7600k with a gtx 1050ti. at that point you might as well pair the thing with a b250 mobo and a g4560 as the gpu will be holding you back. the psu is also really bad and overpriced as well.
yeah I know what you mean. I am trying to make the best system with bang for your buck. there are probably some places where I could save money in the build for things like keyboard and mouse but honestly they should really already have some laying around or just buy some cheap combo at a store near them. the os is another issue though. you could always do what my friend did. he didn't activate his widows license until he had enough money for a copy. you cant do everything on it but apparently it still works. although I didn't see it in person it was just a suggestion he made to me once when I was creating my first build so I am unsure exactly how it works.
You could get an 8400 and a Z370 motherboard, but that would be a bit over budget.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($199.89 @ OutletPC)
Motherboard: ASRock - Fatal1ty AB350 Gaming K4 ATX AM4 Motherboard  ($53.99 @ Newegg)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($92.88 @ OutletPC)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($78.99 @ SuperBiiz)
Storage: *Toshiba - P300 1TB 3.5" 7200RPM Internal Hard Drive  ($39.88 @ Other World Computing)
Video Card: EVGA - GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($399.99 @ Newegg)
Case: Corsair - Carbide SPEC-04 (Black/Red) ATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($52.98 @ Newegg)
Monitor: *Acer - GN246HL 24.0" 1920x1080 144Hz Monitor  ($198.88 @ OutletPC)
Keyboard: Cooler Master - Devastator II Wired Gaming Keyboard w/Optical Mouse  ($24.99 @ Newegg)
Total: $1172.46
Generated by PCPartPicker 2017-12-09 15:34 EST-0500
