hey guys bought a asus n65u a few months ago and i decided to update the firmware and i then tried using my seagate 2tb expansion drive as a cloud drive so i can stream video from it on any computer on the network and so when i enable aicloud my internet goes freakin nuts i am with virgin media and have 60mb down 3mb upload and usually have 40ms ping after enabling aicloud i get over 100ms ping and my xbox 360 lags like crazy and just loading a web page takes longer. on my network at one time i usually have 7 items connected at once
2x xbox 360's
1x pc using the 5ghz network
2x laptops
2x android smart phones
only way to fix it is to revert back to standard firmware now there are 3 firmware updates since my one and i have tried them all and they all have the same problem
really need a fix
CPU: i7 3770k 4.5ghz M/Board: Sabertooth Z77 GPU: Asus Gtx 560 Direct CUii OC RAM: 2x4gb Corsair Veangance PSU: Corsair CX600 Cooler: Custome Water Loop With Gentle typhoon 1850rpm fan, Single 120mm Rad, XSPC Raystorm CPU Block
https://linustechtips.com/topic/8707-asus-n65u-problem/
only after i have activated aicloud and after i disable it the problem is still there so i have to re-install the firmware or backdate it to the firmware it came with
https://linustechtips.com/topic/8707-asus-n65u-problem/#findComment-97052
