I'm looking for a decent gaming machine around $1200. This build is based on a build I saw on LTT but I changed some things to fit my budget. I'm mostly interested in whether 8gb of ram is enough and if $200 monitor is worth it. Just looking for some feedback because I've never built a pc before. Thanks
CPU: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-2400 Memory
Storage: Crucial - MX300 525GB 2.5" Solid State Drive
Video Card: MSI - GeForce GTX 1060 6GB 6GB GAMING X Video Card
Case: Thermaltake - Versa H21 Window ATX Mid Tower Case
Power Supply: EVGA - B3 550W 80+ Bronze Certified Fully-Modular ATX Power Supply
Operating System: Microsoft - Windows 10 Home OEM 64-bit
Monitor: Asus - VG245H 24.0" 1920x1080 75Hz Monitor
https://linustechtips.com/topic/870235-need-help-with-first-time-build/
very decent.
only suggestion i might have, is faster ram.   ryzen really likes fast ram.  if you can push the budget a little to get 3000MHz, the i would. otherwise you're good
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
12 hours ago, CapitalistVN said:
It looks good to me. 8GB is perfectly fine for everyday uses.
12 hours ago, Tsuki said:
very decent.
Thanks a lot I really appreciate it
