Hey LTT,
The Dell CPU fan from my Dell Optiplex 210L broke, so I removed it and added a fan wired to the PSU, which works fine. However, it still thinks the old fan is in their and gives an error message saying “Alert! CPU fan failure”. This means that every time I turn on the computer, I have to press F1. This is normally not a problem, but when I am using the PC as a server, I have to walk down 2 floors to press F1. How can I bypass this?
https://linustechtips.com/topic/870080-cpu-fan-failure-bypass/
did you plug the replacement fan into the cpu fan header, should be able to and that should resolve it... if not, in the bios there should be a section for fan monitoring, should be a spot to ignore cpu fan speed, pretty sure that should take care of it
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/870080-cpu-fan-failure-bypass/#findComment-10792992
No he said it's plugged on the PSU...
Read the post
So the fan is probably molex
https://linustechtips.com/topic/870080-cpu-fan-failure-bypass/#findComment-10793041
Plug another case fan on the CPU fan connector
There might be an option in bios to disable it but am not sure. The fan method will work tho.
It does this beacuse it thinks that your CPU fan isn't spinning beacuse nothing is connected to it
https://linustechtips.com/topic/870080-cpu-fan-failure-bypass/#findComment-10793055
5 minutes ago, BloodyWaters said:
The CPU fan connector to the MOBO is a weird 5 pin dell connector.
Ok, try the bios trick, should be something that says cpu fan speed or cpu fan monitoring or something like that and have options for multiple fan rpms or ignore
desktop
HTPC
https://linustechtips.com/topic/870080-cpu-fan-failure-bypass/#findComment-10793123
