Hey guys!
I am trying to make my cabling look swish but my 24 pin (ATX cable) will just not go right. I am looking for a hair clip like clip which are slots for each cable to keep them inline as they are currently crossing over one another.
Has anyone got any idea where I can find something which will make my cabling be inline? A link would be beautiful, as right now i am looking at it getting angry! :angry::angry::angry:
https://linustechtips.com/topic/86989-24-pin-cable-clip/
Why not just get a 24pin braided cable extension? to make it look nice?
Like: http://www.overclockers.co.uk/showproduct.php?prodid=CB-000-BX
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/86989-24-pin-cable-clip/#findComment-1180356
Already braided my own cables... Just need something to manage them now...
https://linustechtips.com/topic/86989-24-pin-cable-clip/#findComment-1180360
ic, pictures? :D
In that case I would suggest string/wire in the colour of your cables.  Just do a criss cross pattern in-between so each individual wire is wrapped.
Like:
http://colouringbook.org/SVG/2011/COLOURINGBOOK.ORG/dna_black_white_line_art_scalable_vector_graphics_svg_inkscape_adobe_illustrator_clip_art_clipart_coloring_book_colouring-1969px.png
If you know what I mean, so each wire has its own hole, and then pull it tight so its straight.
https://linustechtips.com/topic/86989-24-pin-cable-clip/#findComment-1180379
ic, pictures?  :D
Like:
You can just about see the 24 pin and it just looks messy!
That is a good thought actually! I might try and the string method. Just thought there would be a clip as this must of come up before...
https://linustechtips.com/topic/86989-24-pin-cable-clip/#findComment-1180403
Hey guys!
like this?
https://www.facebook.com/xzone.mod
https://linustechtips.com/topic/86989-24-pin-cable-clip/#findComment-1182062
https://linustechtips.com/topic/86989-24-pin-cable-clip/#findComment-1182858
