LAN gaming using only ethernet cable?
I'm going on vacation soon. I thought that me and my brother could do some LAN gaming Minecraft in case of boredom during our stay. The only problem is that we generally will have no internet on the vacation.
Is it possible to connect an ethernet cable between our laptops and play together? Both of our laptops have an ethernet jack.
Asus X99-A w/ BIOS 3402 | Intel i7 5820k OC @4.4GHz 1.28V w/ Noctua NH-U14S | 16GB Corsair Vengeance DDR4 OC @2666MHz 12-14-14-28 | Asus Geforce GTX970 STRIX OC | EVGA 750 G2 750W | Samsung 850 Evo 1 TB | Windows 10 64-bit | Be-Quiet Silent Base 800 w/ Silent Wings | 2x Dell U2414H OC @72Hz w/ Display Port
Don't forget to invest in an Intel Tuning Plan if you're going to overvolt your K/X CPU
https://linustechtips.com/topic/869430-lan-gaming-using-only-ethernet-cable/
To do this, you would need what is called a cross over cable.
https://en.wikipedia.org/wiki/Ethernet_crossover_cable
Community Standards
"Beast Mode"
Dedicated Streaming Rig
It's actually likely a crossover isn't needed. Most NIC's used in systems for the last 5+ years can work fine with both normal and crossover cables. It negotiates with the other side in what config they'll run :P
The only thing you'll need to do is assign an IP to both NIC's so your pc knows where to send the packages to.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
Most 100Mbps Ethernet-adapters can already do automatic negotiation for that, no special cable needed, and I have never heard of a single gigabit-adapter not having the same feature.
My laptop is from 2012 or so, his laptop too.
so that's okay.
Just put the lan cable in both of your laptops and set up a static IP address for both laptops with the same subnet.
So for example:
192.168.0.1 and 192.168.0.2
With subnetmask:
255.255.255.0
you can leave the default gateway empty and the dns servers you can leave on auto.
This way you should be able to find each other.
Or run an application like this:
http://www.dhcpserver.de/cms/
on one of the laptops to set up the IP addresses.
